Problem pretty much as described here (viewtopic.php?f=33&t=14886).
Machine starts, will drain if water is there.
Shortly after starting there is a short beep – drain pump carries on.
Open the door and the left hand LED is flashing.
There was a small amount of water in the base, but its possible this was from me filling it to check the pump was actually working, also it’s not enough to activate the float switch (if I lift it slightly I can hear a ‘click’.
What little water there was in the base has been removed, but it still does the same and I am wondering what the possibilities are.
Would a failed microswitch on the float cause this behaviour? Other than that, are there other sensors that could cause the same error?
Thanks in advance
