Re: bfi620 flashing 1&3
Hi gents
back to the problem of 1&3 flashing tried a new pcb fitted it drained filled washed stopped the prog to restart on prewash for customer to use back to square 1&3 flashing drains fills then drains leaving the 1&3 flashing looked for earth fault on heater cycle pump all ok but there is a pressure sensor on the wash pump when empty switch made when full switch made what does this do then and could it be the problem toresolve my no wash action
cheers a fed-up alro on this job
