I know its been covered a few times before but Connect are showing that a facia panel is required when you fit the board. The serial is 307080300.
Do I need the panel and what is the correct board.
Thanks in advance gents, I’ve been searching this one for the last half hour and still can’t decide on the right one 😕
the number 307080300 is the commercial code, you will need the serial number to locate the correct part for 100 bit timer module and console panel.
Bob.
Thanks Bob. That explains my confusion. Connect are showing that code instead of the serial number. Whats the difference or relevance in the commercial code?
