BFV62B Not Heating
  • #82559
    modowd
    Hello
    I wonder if you can help
    The dishwasher is not heating and ends cycle with light number four on, but with dishes wet and cold.
    If powered down the dishwasher, just starts the cycle again immediately
    The heater element reads circa 25 ohms which seems to be in spec
    Does this mean that the control board is the most likely problem and if so so can you confirm that it is C00096972
    Thanks for taking time to read this
    #420234
    Seamy
    Re: BFV62B Not Heating
    Make?
    #420235
    modowd
    Hotpoint BFV62B
    seems to share parts with BFI68 DWF40P DWF50 (at least)
    #420236
    That is the correct part number.
    #420237
    modowd
    Do you happen to know if it is also the most likely cause of the problem or are there other possible candidates?
    #420238
    The pcb’s on Indesit machines are a well documented weak point, no heat is a very common failure. 🙁
