Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › bif of a baffler – zan zwf1650, e33/e34 and just wont go,,,
- This topic has 6 replies, 4 voices, and was last updated 14 years, 11 months ago by
gandh1.
May 1, 2011 at 7:34 pm #62529
gandh1
Participantok so, been thru this machine with fine toothed combe.
no blockages,
replaced both p/switches (analogic is nothing like connects pic mind – white and smaller than original part)was getting e34, went to e33 with new parts…
replaced heater,
still e33
replaced drain pump
brushes are plenty, no wiring scrapes, no p/s tube blockages, its just really odd how minute you start it it displays “washing” but then 60 secs later it changes to draining, without modifying end time, then it ends and unlocks door.
yet, every now and again it will start and run to finish fine, apparently. ive had it take in water on a normal programme twice in the last 40-odd goes ive tried, plus it will do a rinse all by itself fine everytime…
only thing i havent done is interlock or solenoids…?
May 1, 2011 at 11:14 pm #350365steve1
ParticipantRe: bif of a baffler – zan zwf1650, e33/e34 and just wont go
hi
i had the same problem last week,replaced interlock,
now all oksteve
May 2, 2011 at 5:54 am #350366Allsorts
Doing an AEG with EXACT same problem at the moment
George
May 2, 2011 at 3:52 pm #350367gandh1
why the heck do these machines never make sense… gonna try an interlock as soon as i can find one to chav off a scrap machine, as thats the only thing i can think of that could be affected intermittently, paid out about £45 on trade spares for this so far, so not spending any more until ive got it sorted, and therefore cant really afford to write it off as i know this cust is the sort that buys something “half price” in a “sale” because its a “bargain” rather than something from us 🙁
cant beleive the programmes corrupted, although, thinking about it, has anyone else had interferance issues from the main feed suppressor with this generation of lux’s??
May 3, 2011 at 7:40 pm #350368Seamy
Its likely to be a problem with the analogic pressure switch or the wiring from it to p.c.b, bad connections etc. Earth fault on heater can cause erroneous e3? faults also, i’m assuming that its not syphoning after pumping out the wash water & continuing to empty as it trys to fill for rinse. It could be a p.c.b fault, if you had one to swap over you could know for sure.
May 3, 2011 at 10:49 pm #350369gandh1
timeline modules are a bit expensive to hold in stock to swap out 😉
im hoping the intermittant operation points towards a variability issue, i.e an environmental/user actuatation. it still nags me that should it be a module fault, id get the same problem consistantly… ???
May 17, 2011 at 1:08 pm #350370gandh1
solved after a complete electric loom strip down and crimp & reconnect. muchos fun.
