Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Big Ball of ice inside the fridge (not in the ice-box)
- This topic has 10 replies, 4 voices, and was last updated 12 years, 3 months ago by
jaffacake2000.
January 8, 2014 at 10:07 pm #78928
jaffacake2000
ParticipantI have this ball of ice that has built-up, will switching the fridge off and defrosting it clear it up and it wont happen again ? Please advise, thank you.
January 8, 2014 at 10:46 pm #407400kwatt
KeymasterRe: Big Ball of ice inside the fridge (not in the ice-box)
That looks very much like an insulation failure.
What machine is and how old is it?
January 8, 2014 at 11:58 pm #407401jaffacake2000
ParticipantRe: Big Ball of ice inside the fridge (not in the ice-box)
its a whirlpool and about more than 7 years old
January 9, 2014 at 12:13 am #407402kwatt
Most likely the insulation then and, I’m afraid it’s terminal.
January 9, 2014 at 1:41 am #407403admin
If that is the first time it’s happened and you haven’t cleared it before then the likely cause is that something has been touching the back wall and as it’s been defrosting and restarting it builds up like that over a while.
Turn off for a few hours and defrost it.
Then restart.If it comes back in the same place then it’s possible insulation or restriction.
Bryan
January 9, 2014 at 2:56 am #407404jaffacake2000
ok, thanks, i will try defrosting it. yeh, it is first time and havent cleared it before. The fridge is about 2 cm way from the kitchen wall and the only things that touch the wall inside the fridge are food and containers
January 9, 2014 at 3:01 am #407405jaffacake2000
kwatt wrote:Most likely the insulation then and, I’m afraid it’s terminal.
what does that mean ? how much will an engineer charge to come out and fix it ?
btw, I used to hear loud clicking or single banging noises coming from the fridge it happend for about 2 – 3 years now its stopped and i could only hear it during the night. It was one click or bang every 30 minutes or so
January 9, 2014 at 6:45 am #407406kwatt
jaffacake2000 wrote:what does that mean ? how much will an engineer charge to come out and fix it ?
If it is the insulation it means that it cannot be repaired.
January 9, 2014 at 1:53 pm #407407jaffacake2000
These appliances cost a lot of money, how and why do you think insulation failure happen ? I mean we dont misuse the fridge wouldnt know how to but only use it to store food
January 9, 2014 at 3:52 pm #407408kwatt
It can be caused by any number of reasons, the most common one being the installation environment in all honesty.
January 9, 2014 at 6:23 pm #407409Seamy
The walls of the appliance are filled with an insulation material to keep the cold inside the fridge. If this insulation breaks down or cracks for instance then there is a hot spot where there is heat ingress from outside. At the point of breakdown there will be frost/ice build-up normally apparent internally within the appliance as shown in picture.
