Big Bosch
  • #37661
    Part tech & part spares query.
    Model WBB24759GB-01
    Not seen it yet, in residential home, hole in door seal.
    Tech question, how difficult is a door seal change on one of these ?
    Parts query, two different seals shown, 243834 around £68 and 445193 at £38.
    Would I be correct in thinking that the more expensive one is either butyl or EPDM or some other grease/fat/bleach resistant rubber?
    Re: Big Bosch
    Hi Jim,
    Front comes off (bottom screws are at the side) and a clamp band. Weights in two halves, so band is accessible.
    No idea about the door seals.
    don
    Re: Big Bosch
    Hi Jim
    Info from e shop on those two part numbers
    Bosch E Shop wrote: Part no. 445193 Substitute part no. 667489 Boot gasket Door seal, washer, w/o flushing hose port
    Part no. 243834 Substitute part no. 246270 Boot gasket Gasket holder, white, with boot & labels. 68.29 GBP
    HTH
    Don
    #255972
    Re: Big Bosch
    Thanks Don, it looks as though I will have to pay a visit, just in case this one has a ‘flushing hose port’ :rolls:
    Thanks Chris as well, 😉
    gegsy
    Re: Big Bosch
    Logixx 9, nice piece of kit 😀
    You have mails Jim
    Re: Big Bosch
    Thanks Greg, is there any way of knowing which of the two seals it might need without going to have a look?
    gegsy
    Re: Big Bosch
    Only showing one here 😕 246270 £58.12 + the usual
    gegsy
    Re: Big Bosch
    Update 😀
    445193 which is part change now to 667489 and used FD8505 & thereafter 8)
    Re: Big Bosch
    Did this seal a couple of weeks ago, a bit of a struggle if you change the whole kit with new plastic seal surround.
    Now have a query on another one. Customer( on the phone) is complaining of poor spin.
    I have got them to check the filter, nothing much in there. Now trying it without a load to eliminate possible OOB.
    Any other possibles, will apparently rotate but not pick up speed to spin.
