Bissell 1698-k
  • #33934
    tanner
    hi guys,
    Long shot i know but do’s anyone have a idea why my bissel has stopped pumping water is there a common fault so to speak.
    i have been inside and checked all piping and still nothing.
    i have a felling it is the pump but were can you by these parts from.
    rgds
    stuart
    #240598
    spanner51
    Re: Bissell 1698-k
    If the water still squirts out of the hose but not the bottom, then its probably blocked in the heater. Quite a common fault.
    #240599
    tanner
    Re: Bissell 1698-k
    hi mate,
    no it does not come out of both bottom and hose, some will come from th hose every now and then???
    rgds
    stuart
    #240600
    SWERV
    Re: Bissell 1698-k
    The pump belt could be worn, very common on these.
    Merv
    #240601
    tanner
    Re: Bissell 1698-k
    hi merv,
    no pump belt seems to be ok??
    rgds
    stuart
    #240602
    SWERV
    Re: Bissell 1698-k
    In that case I’d definately check for a blockage in the heater.
    Merv
    #240603
    Re: Bissell 1698-k
    we get a lot of pumps failing due to customers putting them away without flushing tubes through with clean water
    in insructions it states you should turn dial to water only to flush machine through at the end
    agree with above heater gets blocked but will normally still pump through hose if this is the case
    if you still get problems repost and i will ask the member of staff who does a lot of these
