Home › Forums › Public Support Forums › Help And Support › Vacuum Cleaner Help Forum › Bissell proheat 1698k
- This topic has 5 replies, 4 voices, and was last updated 8 years, 4 months ago by
sutty86.
November 29, 2017 at 7:40 pm #92740
sutty86
ParticipantBought this model off shpock, rookie mistake didn’t fully check before purchasing.
Live quite far away and guy is refusing refund.
I’m under the impression it’s hopefully an early fix but atm I’m stuck.
Basically the unit is in good user shape..
It’s basically not spraying water out, both the jets under the brush and the hand tool jet is rubbish, squirts out in intervals very low pressure for around 1 second then stops.Brush bar is fine, heater core is fine and clean,
I can see fluid moving around tubes inside when button is pressed on main unit,around the heat module.I think my problem is the tank hose which connects to base.
It fits onto a nipple on the base, I’ve tried sticking a screw there but the water just leaks under the connection.Any help guys
November 29, 2017 at 9:01 pm #452039don
ModeratorRe: Bissell proheat 1698k
Very few spares are available for these machines and no service back up at all.
Your best bet is to return it to Bissell repair comes with a guarantee. Not the best news you want to hear but at least it gets you a fully working machine.
DonNovember 29, 2017 at 9:51 pm #452040sutty86
ParticipantRe: Bissell proheat 1698k
Dam I was hoping for an easy fix
ThanksNovember 29, 2017 at 10:50 pm #452041electrofix
check the bottom of the main tank
if someone has put water that’s too hot in the container the base of the container warps upward stopping the water flowing properly
September 16, 2020 at 6:47 am #452042asdf1234
ParticipantYes, that’s a problem. I generally use a wand for cleaning carpets and the effect is just superb. I don’t remember the last time I took the carpets away for cleaning.I hope you fix your problem, you can also search this blog for solutions to your problem, because as there are articles about frequent breakdowns of vacuum cleaners.
September 16, 2020 at 8:41 am #452043electrofix
Moderatorasdf1234 wrote:Yes, that’s a problem. I generally use a wand for cleaning carpets and the effect is just superb. I don’t remember the last time I took the carpets away for cleaning.I hope you fix your problem, you can also search this blog for solutions to your problem, because as there are articles about frequent breakdowns of vacuum cleaners.
the type of carpet cleaner you are talking about is totally different. the one above is a self contained upright unit whereas yours has a long tube from the vacuum and water supply unit. both have their merits
have removed your link as it does not help the thread plus this thread is 3 years old
