Home › Forums › Public Support Forums › Help And Support › Vacuum Cleaner Help Forum › Bissell ProHeat 2X 9200-E
- This topic has 6 replies, 4 voices, and was last updated 11 years, 1 month ago by
kaysee1942.
February 14, 2015 at 6:29 pm #84100
kaysee1942
ParticipantThe brushes on the subject carpet cleaner do not rotate (everything else functions normally). I changed the circuit board the handle but that made no difference. I checked the output voltage of the new circuit board and it was zero. I then checked continuity to the brush motor terminals from the circuit board and that was zero ohms – however, the motor was open circuit and so I have ordered a new motor.
My concern is that the output voltage of the circuit board is not 250V AC (the same as the motor). Does the fact that there is no load on the circuit board have a bearing on the output voltage?
February 15, 2015 at 4:23 pm #424721kaysee1942
ParticipantRe: Bissell ProHeat 2X 9200-E
I have a further query. The service manual for the 9200E states that the output of the circuit board is 240V DC (direct current) and yet the wires feed direct to the brush motor (via the brush micro switch) and, moreover, the motor ID plate states that it is a 250V AC 50Hz motor. Surely the output from the circuit board cannot possibly be DC.
February 16, 2015 at 9:04 am #424722don
ModeratorRe: Bissell ProHeat 2X 9200-E
These are very low volume machines usually shipped out at silly prices by the nationals.
You are probably best off in returning the whole machine to Bissell who will repair, service and guarantee the repair for three months. The £75 fee includes carriage both ways as well.
DIY repair? There is an article on the Bissell support site here which may help.
HTH 🙂
DonFebruary 16, 2015 at 10:58 am #424723kaysee1942
Many thanks for responding. I have already purchased a new circuit board and brush motor (ordered but not arrived yet) and so I am not keen to pay another £75 to return the cleaner to Bissell – it’s a pity I did not know about their repair service earlier.
I will fit the motor when it arrives and see if that fixes the problem. I am still concerned as to why the service manual for the 9200E states that the output voltage of the circuit board should be 250V DC when the motor currently in the cleaner has a plate stating it is 250V AC, 50Hz. The circuit diagram in the service manual (yes it is for the 9000E) shows a direct connection to the brush motor (via the micro switch). I have asked Bissell for advice on this matter but they have failed to respond.
February 22, 2015 at 1:24 pm #424724macman35
Presumably the same arrangement as on the Dyson brushroll motors, they’re DC motors fed at around 240V from the PCB.
May 20, 2015 at 11:44 am #424725sbaz2836
___________________________
aliiiMay 20, 2015 at 12:05 pm #424726don
It’s either a typo or a bad translation from Chinese to English. Happens a lot these days :rolls:
Don -
