BLACK RESIDUAL DUST ON CATALYTIC OVEN LINERS
Home Forums Public Support Forums Help And Support Cooker And Oven Forum BLACK RESIDUAL DUST ON CATALYTIC OVEN LINERS
  • #88194
    dimmy
    I bought a zanussi electric oven with catalytic so called “self clean” oven liners a year ago and am pleased with it EXCEPT for the catalytic liners!. The bottom of the oven is smooth enamel and is very easy to clean with soap and warm water. However as much as I try to eliminate the black residue/dust on the catalytic liners the cloth always remains black…it is driving me mad!. Enamel as per the bottom would be much easier to clean. I did as, per the manual,l clean and “burn in ” the oven for an hour before first use. Is this black residue normal and will always be there?. and what about if it get on the food?,. Each time I slide a tray out some dust falls from the sides onto the oven base. CAN I vacuum the sides to get rid of the dust?…the sides are a very rough service so it is very difficult to wipe a cloth over them!….advice appreciated….thanks
    #437315
    Re: BLACK RESIDUAL DUST ON CATALYTIC OVEN LINERS
    You cannot clean the catalytic liners with any type of cleaning agent or cloth. The rough carbon like surface is designed to self clean when normal oven heat is applied. The ‘dust’ is the fall-out of fat from the liners surface that falls on the oven base. There comes a point in the life of the liners where excessive fat saturation cannot be contained and the only recourse is to purchase new liners.
