Blanco Extractor Hood – Lights not working
Home Forums Public Support Forums Help And Support Other Appliances Blanco Extractor Hood – Lights not working
  • #85065
    vidmarc
    Any suggestions? The bulbs look OK but figure I should try replacing them.
    What voltage should I be looking for? There’s a circuit diagram that says 2 x 20 Watts max but doesn’t list the voltage.
    #427588
    don
    Re: Blanco Extractor Hood – Lights not working
    Model number is always good so we know what to look for 😉
    If they are like the attached then they are G4 20W halogen capsules. Avoid touching the glass with your fingers as the natural oils from your skin creates a hot spot and the lamp will blow. If you have a multimeter a quick continuity test will tell you if they are okay.
    HTH 🙂
    Don
    #427589
    vidmarc
    The model number is BE/C/1029/S
    The bulbs look fine. Sure they haven’t blown so my guess is it’s the switching unit/circuit board at the front that’s the problem.
    #427590
    We have never managed to source Blanco spare parts, no idea who does them or if you can even get them I’m afraid. 🙁
