blank off nuts
  • #66555
    Cras
    Can anybody tell me the cheapest place to purchase blank off nuts for hot taps,have seen plastic ones in use but have never seen them for sale ? thanks Cras
    #364533
    don
    Re: blank off nuts
    Hi Cras
    Not seen or used any plastic ones. We use only the brass ones and have had no problems whatsoever. Connect have BLK9029 a 10 box pack or Qualtex QUALPG44. Both come out at 89p for each cap.
    Don
    #364534
    Re: blank off nuts
    I still think that P45’s method is as good as it gets.
    Cut the screwed end off one of the old fill hoses,remove seal, slot a 10p piece in, refit seal, you now have a perfect blanking nut, job done. 8)
    #364535
    Re: blank off nuts
    BES have them but you’ll still need to use a washer.
    http://www.bes.co.uk/products/158b.asp#6608
    bryan
    #364536
    Re: blank off nuts
    A 10p piece is much cheaper than any of those. 😀
    #364537
    Re: blank off nuts
    The 10p works OK but I think they’re made of plated steel these days, aren’t they? If so, the rust will get through it in maybe 10 or 15 years. Better to carry a brass one in the toolbox, they’re cheap enough and it looks a bit more pro. (Not that I worry about appearances but I know many of you do.)
    Mike.
