Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bleedin, blooming Bosch!!
- This topic has 10 replies, 4 voices, and was last updated 20 years, 2 months ago by
Nona.
January 26, 2006 at 10:01 pm #15175
Nona
ParticipantHelp!! 😯
I need some advice on model SGS56E02GB/35…it keeps missing the drying stage and keeps washing/rinsing up to 1 minute and then just doesn’t stop. I’ve had a look at the control module and there’s no obvious sign of a burnt-out resistor, or any cracks in the circuit board. It could be the heating element, but I reckon the element is ok and the control module isn’t sending the right pulse (or whatever..) to kick-in the drying phase. Do you think I need a new module?
I need help quick coz the missus is making my ears bleed!! 🙄
Jeff
January 26, 2006 at 11:40 pm #162488gegsy
ParticipantRe: Bleedin, blooming Bosch!!
I would inspect the tank on the left side and internal pipework inc pressure unit for gunge as this is teh usual problem for odd faults like this.
January 26, 2006 at 11:58 pm #162489Nona
Thanks for the reply…I did give all of the filters a good clean, checked the waste hose, and also the pump impellor (no damage).
I’ve also just found out that the water is cold…even on intensive selection…would a faulty element cause the module to miss the drying stage?? 🙄 🙄
January 27, 2006 at 12:25 am #162490gegsy
If there is no heat then the drying cycle would not be skipped but very poor if existent.
January 27, 2006 at 11:26 am #162491Nona
I’ve just tried another wash…2hr 7min, 50C…after 1hr 50mins, it was still showing over 1hr left and was still washing. It hadn’t started rinsing and the water was cold. Is there somewhere you can buy 2nd-hand Bosch parts?
January 27, 2006 at 7:17 pm #162492gegsy
I dont know anywhere you can get 2nd hand parts, although I wouldnt use 2nd hand parts because there is no guarantee of their credebility.Its obviously a heating problem but I think its engineer time as we have covered as much as we can. Try the link below for your nearest engineer.
January 27, 2006 at 7:18 pm #162493Penguin45
Exceptionally complex machine – digital control board can play up, heater failed, underfilling can all cause the problems you are describing. Probably time to bite the bullet and send for the engineers.
Check the link below. Power off if investigating further.
Penguin45.February 12, 2006 at 11:23 am #162494AndySwiffin
Nona wrote:Help!! 😯
Jeff
Me too. Timer counts down to 1 minute and machine then just continues.
Just checked and it doesn’t seem to be heating the water. No obvious damage to the control board.
Faulty heating element?
Andy
February 12, 2006 at 1:28 pm #162495AndySwiffin
AndySwiffin wrote:
Just checked and it doesn’t seem to be heating the water. No obvious damage to the control board.Faulty heating element?
Andy
Sad this, replying to your own posts 😀
Been in with the old AVO 8 – the heating element is totally open circuit.
Checked voltage applied on auto program and quick program. on auto there’s no voltage across the heater during the prerinse and the voltage appears just as the tablet dispensor opens. On quick, voltage comes on about 5 minutes in – also when the tablet dispensor opens. I assume the little brown thing in the middle of the element is a water sensor cutout in case of too little water? I checked and that’s working ok – voltage was measured across the actual element terminals.So – I guess my heating element is gubbed?
Andy
andy.swiffin at blueyonder.co.ukFebruary 12, 2006 at 1:36 pm #162496Penguin45
AndySwiffin wrote:So – I guess my heating element is gubbed?
Correct – p/no 483058. Email to spares@ukwhitegoods.co.uk for prices and ordering.
For future readers, UKWhitegoods cannot condone the live testing of appliances. Please don’t.
Penguin45.February 13, 2006 at 12:59 pm #162497AndySwiffin
Penguin45 wrote:
AndySwiffin wrote:
So – I guess my heating element is gubbed?Correct – p/no 483058. Email to spares@ukwhitegoods.co.uk for prices and ordering.
Penguin45.Many thanks for the information. (and thanks for this most useful site)
You’re quite right – I should have thought more carefully before posting what I’d done 😳
Anyone reading this thread – unless you’re suitably qualified NEVER work on live equipment. I should add that I’m an Electronic Engineer and Radio Ham who regularly works on equpiment with over 2000 volts exposed so I’m fairly experienced at working in dangerous environments. Unless you know what you’re doing (not just think you know) don’t even think about it. YOU CAN DIE DOING THIS KIND OF STUFF. 😥
cheers
Andy Swiffin -
