Home › Forums › Public Support Forums › General Enquiries And Questions › Blockage error code – Hoover Optima WMH 148 DF
- This topic has 6 replies, 3 voices, and was last updated 12 years, 6 months ago by
SimonWilson.
September 15, 2013 at 2:22 pm #77152
SimonWilson
ParticipantHello, thank you for reading…
I have recently connected my washing machine after moving and renovating the new house to make it liveable. I have run a well-known washing machine cleaner through the system, but this dislodged the general scum that collects in the pipes and had dried out.
Having fully unblocked the sump filter, all pipes and drum so that there is no scum left… when I start the machine it just fills and fills with water. The drum does not move and the pump does not kick in.ERROR CODE – Shows an ‘hour glass’ image flashing with the number ’58’ next to it… also the red lights for the ‘Cold wash’ and Sensitive care’ are flashing.
Questions:
1, Is there a ‘button rest sequence’?
2, do I have to call an engineer (I would love to avoid this!)?Thanks again!!
September 15, 2013 at 3:21 pm #401185Martin
ParticipantRe: Blockage error code – Hoover Optima WMH 148 DF
Just filling with water indicates the air pressure chamber (built into the drum) is blocked with gunge. Power off, then try blowing down the air pressure tube (small thin rubber hose) in the hope of clearing the blockage in the air chamber.
September 15, 2013 at 3:47 pm #401186Andy jones
If you don’t find a blockage check the hose for little nicks that would allow ain’t to escape
Sent from my iPad using Tapatalk HDSeptember 15, 2013 at 3:48 pm #401187Andy jones
Air to escape
Sent from my iPad using Tapatalk HDSeptember 15, 2013 at 3:58 pm #401188SimonWilson
Unfortunately that did not work… no air escape or blockage. I could hear the bubbles created in the resting water in the drum.
On any setting the machine just fills… showing the same error.September 15, 2013 at 4:25 pm #401189Martin
Hmmm? I wonder if you got water in the electronics when taking the bottom hoses off? Didn’t lay it on its front or right hand side perhaps?
September 15, 2013 at 9:28 pm #401190SimonWilson
Thanks again. The error has been the same throughout, so I doubt that any further complications happens.
