Blomberg 1301 ABB bearings
Home Forums Public Support Forums Spare Parts Help Blomberg 1301 ABB bearings
  • #16669
    D Zil
    …making increasingly rumbly sounds…
    Can you supply these (they’re not shown in your shop), how much and are they an easy job for a competent DIY-er/mechanic?
    I presume it’s best to replace the seal at the same time, will I need anything else?
    Great site BTW – I’m for a Miele next time around! 8)
    #170961
    Dave_Conway
    Re: Blomberg 1301 ABB bearings
    There is no bearing kit as such for this model I’m afraid, the bearings will be generic, the seal is around £25 which will need replacing.
    You’ll need to to do 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the job beforehand and let us know the bearing sizes please (Blomberg/Brandt the manufacturer) show the bearings but have a horrrendous price tag of £20+ for each bearing when they can easily be supplied for less than half that 🙂
    The bearing numbers will be 620?, possibly 6205 and 6206 I think for this model (anyone confirm ?)
    Power off of course 😉
    #170962
    MP no. BB05100, perhaps?
    Dave_Conway
    BB05100 Contains 2 x 6205 bearings and the seal is 30×62/75×10/16 which should be stamped on it normally.
    If you could confirm those sizes are correct when the machine has been dismantled I can sort the rest for you 🙂
    #170964
    D Zil
    Thanks for the responses. OK, I’ve interrupted the Missus’s (wash) cycles 😳 to discover:
    Outer Bearing is stamped Italy-B W 5KF 6305-2Z/C3
    Inner Bearing: Malasia 216 164 W 5KF 6306-2Z/C3
    Seal is: Rolf 35 72/79 11/16 FL
    Looks like you were right first time, Dave!
    Machine is now in bits, I could use the parts before next weekend if possible. Pls call me on *********** when you’re ready.
    Thanks a lot – Tony
    #170965
    Dave_Conway
    6305 and 6306 bearings are not a problem, the seal will be as described in my first reply.
    Could you send an email please to spares@ukwhitegoods.co.uk with the model number and the two bearing sizes above and I will sort from there for you 😀
    I’ve edited your reply as you really don’t want to leave your mobile number in a public forum that gets + 20k hits a day 😉
    #170966
    D Zil
    Thanks very much for all your help, repair went fine and the machine is now reassuringly quiet!
    Great help, great service, great site!
    Thanks – Tony
