Blomberg 1301 ABB cut out & will not start…
Home Forums Public Support Forums Spare Parts Help Blomberg 1301 ABB cut out & will not start…
  • #8529
    My Blomberg 1301 ABB cut out yesterday while on a wash cycle and now will not turn on.
    I have replaced the fuse in the plug and am now also using a rcd (both of which i have tested and are working perfectly)
    The machine shows no life what so ever when plugged in / turned on (not even the ‘door lock’ light.)
    Upon opening the top of the machine i noticed the earth wire attached to the top of the drum had become disconnected – it is now reconnected. No damaged components/wiring could be seen upon initial inspection.
    Any one got any ideas? am i missing something as simple as a reset switch…?
    #129192
    Dave_Conway
    Re: Blomberg 1301 ABB cut out & will not start…
    Probably the door interlock on these models, quite a common failure.
    If you’re unsure of how to go about checking, please call an engineer, you can check in repairs@ and the directories for one near you.
    If you are going to have a go yourself, pull the plug 1st please :zap:
    I’ve also deleted you’re other rather longer post as there’s enough info in this one to be able to advise 😉
    #129193
    This realy could be anything, suspect the timer/cotrol unit though which sometimes goes bang by itself or somethng else like the motor can cause it to go.
    A complex machine and I would advise expert help.
    click here to try our repairs@service
