Blomberg 1301 ABB washer – fitting heater element
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Blomberg 1301 ABB washer – fitting heater element
  • #29867
    farway
    My Blomberg 1301 ABB heater element failed [short direct to earth]
    yesterday.
    I have removed the old failed element & a new element is on it’s way
    My query is how do I refit the new one?
    It would seem simply a matter of lubricating the “o” type seal fitted to the element & forcing it in to the hole, but having practiced using the old one I find overcoming the rubber seal around the element is going to be a problem
    Any advice or tips or is it just brute force that is required to overcome the restistance of the seal?
    As a new poster I think I should tell you I am an electrician of 40 plus years, but not on washing machines
    Mike
    #224969
    Re: Blomberg 1301 ABB washer – fitting heater element
    New one will slide straight in. The grommet seal on the old one is distorted by years of compression. Make sure you get the element through the stabilty bracket.
    farway
    Thanks, I have not seen the stability bracket but now you mention it I shall have a good look for it.
    I assume this is internal to drum somewhere?
    #224971
    Correct, in-line with the path of the element.
    farway
    Thanks yet again, just had a good look with a torch, it is so obvious once made aware of it
    Now all I need is the postman next week & hopefully home & dry
