My blomberg has stopped spinning! It drains ok but then just stops.
When you try on spin/drain cycle the pump runs, ( for about 5 seconds) stop runs again stops then the lights flash alnog with the beeper.
I have checked the pump – it doesent appear to be blocked, the pressure bell appears to be clear (When you blow gently you can hear the presure switch clicking )
