Re: Blomberg 1315 AAB Please Help
Blomberg is made by Brandt who’s tech support……… isn’t. So – apply some logic here – what has actually happened? Does the machine still have water in? If it does, it ain’t going to spin……… Can you hear the pump running? Is the filter clear? If the water has gone, the out of balance system may be activated. If the machine can’t balance the load, again it won’t spin – it may be shown as a fault.
If the above doesn’t apply, switch off, pull the plug and leave it for a while. It may forget whatever it was up to and re-programme when restarted.
HTH,
