Blomberg 1500AW – door reversible
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Blomberg 1500AW – door reversible
  • #27132
    cirks
    unfortunately we’ve lost our instruction booklet for the Blomberg 1500AW and can’t find it online. Could you let me know whether the door is reversible? The hinge and lock mountings are identical by the look of it and the only thing that looks like it may cause a problem is switching the side the solenoid cabling runs from right to left.
    Thanks in advance
    #212731
    Re: Blomberg 1500AW – door reversible
    You can reverse the door quite easily. The button mechanism needs to be reversed as well – snap fit into panel. Door itself must be stripped and reversed as well.
    Power off for the inside part.
    cirks
    Penguin45 wrote:You can reverse the door quite easily. The button mechanism needs to be reversed as well – snap fit into panel. Door itself must be stripped and reversed as well.
    That’s great thanks – I’ll have another look over the weekend (particuarly at the button mechanism)!
