Blomberg 1500AW washer not spining
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Blomberg 1500AW washer not spining
  • #10606
    pipmac
    Blomberg 1500AW. My washer has stoped spining, I can do a wash, rinse but no spin unless I reset the program dial to spin and then again it is intermitant. I have replaced the corben brushes and from the 1500 and the 1200 spin speed it dose not work, (it used to and I have gone down the scale) but works on the 900 setting now if the programe dial is reset, sometimes!. Can it be repaired and at what cost ( a DIY person) It is about four and a half years old, and I have had no problems with it upun till now. Is it at the end of its lifespan, the motor sounds lovley( thinking about turning it in to a lathe). I have also been on the WITCH web site and one of thire best byes is the BOSCH WF02467. what do you think.
    pipmac
    #141095
    Re: Blomberg 1500AW washer not spining
    Probably a simple problem, Pip. Chech this:
    http://www.ukwhitegoods.co.uk/modules.p … t=blomberg
    A common problem and simple to resolve.
    pipmac
    Great, thanks, a five min job, washer working perfect. have canceled my order for a new washer. Thanks again you have saved me £££££££££££.
    Pip
