Can anyone please help, my Blomberg washer is 7 years old and has been a superb machine, that is until now when it has started to NOT take the conditioner… any help will be very much appreciated. 🙁
Remove drawer. Clean roof of chamber thoroughly. Prick out the holes above the conditioner compartment, see if that gets things going. If not, you may have a dead coil on the inlet valve.
blimey Penguin that was a quick reply,, I have just been in and cleaned all the holes out,, what I’m a bit confused about is that the holes are over the wash powder sections but there isn’t any holes over the conditioner compartment,, am I being a prat??
Three way inlet valve has a pcb soldered to the top, so theoretrically it’s a question of replacing the entire valve. Each coil should meter at 3–4kOhms when tested.
