Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Blomberg 1501AAA
- This topic has 7 replies, 4 voices, and was last updated 16 years, 11 months ago by
Shyde15.
April 20, 2009 at 12:45 pm #45109
Shyde15
ParticipantMy washing machine recently stopped the spinning cycle and the chugging of the pump was very noticable. I checked the pressure bell and cleaned it out. I have taken the pump off and clean around the magnet and put it back on, now the pump makes noise as though the fan inside is spining but the chugging noise as stopped and still does not spin. any Ideas or is it a new pump again??
Regards
Steven
April 20, 2009 at 2:39 pm #283654Specialist01269
ParticipantRe: Blomberg 1501AAA
Was there any water left inside the machine ? & have you checked that the outlet pipe from the pump to the sink is clear, you also need to check that the connection to the sink is clear.
April 21, 2009 at 7:06 am #283655Shyde15
ParticipantSpecialist01269 wrote:Was there any water left inside the machine ? & have you checked that the outlet pipe from the pump to the sink is clear, you also need to check that the connection to the sink is clear.
Well most the water was soaked into the towels, 2 meduim size towels and a large one.
Normally the chugging happens on pump cycle then the next cyle is spin, but nothing happened.
I need to find this out quick, the Wife is getting impatient, and wants to know if we should get a new one , Help!!
April 21, 2009 at 7:17 am #283656Dales-Electronic
ModeratorRe: Blomberg 1501AAA
Two questions – does the pump drain the water away? Secondly, with no washing in the drum does it spin?
If the water is not draining then you have a blockage or the pump is faulty. If it spins with no load then you should be looking at the motor area.
April 21, 2009 at 7:58 am #283657Shyde15
ParticipantRight I have cleaned out the oulet pipe and put in a wet towel and a prestow it now works. Is it normal to be sparking from the motor, its seems to be making a bit of noise on 1500, 1200 spin mode but sounds fine at 900 any Ideas???
April 21, 2009 at 8:33 am #283658Shyde15
ParticipantWell I have just put a load in and now the wash cycles not working and not turning. Whats happening. help!!
April 21, 2009 at 9:38 am #283659April 21, 2009 at 10:10 am #283660Shyde15
ParticipantCheers I have come to the conclusion that it is the brushers that’s gone , but they have lasted 9 years so, cheers! for the advice.
Hopefully that’s thatBye all!
