Blomberg 1501AAA not spinning
Home Forums Public Support Forums Spare Parts Help Blomberg 1501AAA not spinning
Viewing 12 posts - 16 through 27 (of 27 total)
  • #113878
    cirks
    Penguin45 wrote:Right………
    To do this, you should have removed a small plastic bottle with a tube on top? This is the collecting bell and must be cleaned thoroughly.
    The grommet has a lip turning down on the inside, which will obstruct the passage of any implement pushed through, so be careful. Best way is to actually remove it and wash it.
    Penguin45 – a quick search on Google found this link and your answer to my problems (well, the machine’s rather than mine 😉 ). Just a note to say thanks 🙂 Machine back up and spinning, wife almost happy 😉
    #113879
    cirks wrote:Machine back up and spinning, wife almost happy 😉
    About as good as it gets then………. 😀
    Glad you sorted it.
    COLING
    Re: Blomberg 1501AAA not spinning
    Hi Penguin 45
    I camwe across your advice last night after our machine stopped spinning. I followeds your instructions and all seems OK now. 😆
    #113881
    thekitehunter
    Just another thing to check, after mine stopped spinning I found that one of the wires had come off the sensor at the bottom of the drum – putting that back one cured it.
    #113882
    el_steveo
    Hi – I Have a slightly different Spin issue with my Blomberg – its operator (the wife 😀 ) has a tendeceny to run it always at max RPM (1500)on spin…recently its started tripping a circuit breaker when its on its spin cycle……so I reduce the spin speed to 1300 and it doesn’t trip the breaker anymore but it does sound like its having a job maintaining the spin speed, therefore I suspect the belt is maybe slipping or worn out (its about 5yrs old)
    Anybody know which belt I should buy and where I can get it – most of the net sites dont seem to stock them….or if you have any other suggestions I’d appreciate it .
    Many thanks for looking.
    #113883
    Drive belt won’t trip the circuit breaker.
    Motor brushes probably worn. You may need these:
    http://shop.ukwhitegoods.co.uk/product_ … cts_id=326
    Power off if handling motor.
    el_steveo
    Hi Pengiun,
    Had a look at the carbons they are only about half way through – I took out the motor cleaned it up reinstalled it. Cleaned out the little port on the front of the machine (there was a bra wire in there) – anyways its still not working.
    What happens now is it starts to rotate then stops , waits a few mins goes to start a rotation then stops etc etc….pump seems to be ok , motor is turning , the drum rotates but seems to trip out after 1 sec..
    I also cleaned out the pressure bell , but didn’t notice anything suspect (very small amount of sludge).
    I suspect maybe elctronics prob now – any ideas ??
    Somebody mentioned an unbalance sensor – ?
    #113885
    el_steveo
    Update – called out an engineer….checked it all out – fault is in the electronics……time for a new machine….
    #113886
    pendragon
    Just found this as mine has stop spinning, just wanted to ask how easy is it to get the pressure bell out. Do I need to dismantle the back or does it just clip out.
    Must admit not good at taking things apart (with out breaking them that is 🙂 ) so not sure if I should just get an enginer out.
    #113887
    Power off, rear cover off, bottle is just a push fit…… It’s all in the first few posts on P1 of this thread.
    pendragon
    Thanks Penguin45 for the quick reply.
    Done that, it was a bit stiff which was why I was unsure if I was missing something.
    Still no spin, Decided to try a wash to see if everything else was working, its not, what It does is get to the main wash bit and stop (didn’t do pre-wash or anything).
    Any Ideas would be gratefully received.
    #113889
    wilderness
    Thanks Penguin45, just had the spin problem with our 1501 and followed the instructions.
    Worked a treat!!
    Wife is VERY happy, may get some horizontal jogging !!! 😆
