Blomberg 1501AAA not spinning
Home Forums Public Support Forums Spare Parts Help Blomberg 1501AAA not spinning
Viewing 15 posts - 1 through 15 (of 27 total)
  • #5810
    Everything else appears to be working OK, the drum turns normally, the pump works and everything but the machine just sits still with the pump running when it gets to the spin part of the cycle.
    Ive taken out the adjustable spin speed knob and cleaned the contacts – this made it work for a couple of washes but now it refuses to spin again
    any ideas or places to get parts and what may be the problem would be greatly appreciated 🙂
    John
    sa5135[AT]eclipse.co.uk <- swap [AT] for @ 😉
    #113864
    Hi John,
    This range of machines is notorious for the “pressure bell” becoming choked with old soap and similar sludge. It does not depressurise, so the machine thinks it is still full of water and will not spin.
    The bell is on the bottom centre rear of the tank.
    Pull the plug FIRST.
    Re: Blomberg 1501AAA not spinning
    thanks for the quick reply – I’ll have a look tomorrow, not sure I should get into that kind of think at this time or I’ll likely be up all night 😆
    cheers
    #113866
    John,
    Clean out the rubber grommet as well as the chamber.
    Penguin.
    #113867
    Tried this tonight although I may not have been forceful enough with the grommet
    It seemed to come to an end instead of just going straight through – i didnt want to ram a screwdriver in too hard though incase I broke anything before checking here
    Is this likely to be the blockage thats causing the problem, or is it designed that way and I’ll break something by forceing a screwdriver through?
    thanks for all the help 🙂
    John
    #113868
    Right………
    To do this, you should have removed a small plastic bottle with a tube on top? This is the collecting bell and must be cleaned thoroughly.
    The grommet has a lip turning down on the inside, which will obstruct the passage of any implement pushed through, so be careful. Best way is to actually remove it and wash it.
    Yup
    took off the bottle and cleaned thoroughly, didnt remove the grommet but gently wriggled a screwdriver around and managed to get a fair amount of slimey gunk out.
    First test the spin worked, on doing a full wash it didnt spin again
    Then today its worked perfectly for three loads
    Really appreciate all the help – I know what to do now in future too
    :tup:
    Regards
    John
    #113870
    Nice one …….. Bear in mind that being a digitally controlled machine it has an “out of balance” set up as part of the electronics. Occasionally the machine will not spin due to an offset load. Resetting to last rinse and spin will generally get things going again.
    Thank you Penguin 45, you are a star!
    I found this post last night and my machine is now working brilliantly again.
    #113872
    debs
    Hi, I read about needing to clean the ‘pressure bell’. How do I get to this please?
    Debs
    #113873
    clyde
    debs wrote:Hi, I read about needing to clean the ‘pressure bell’. How do I get to this please?
    Debs
    Can’t tell you exactly how to carry out the repair but first unplug the machine :plug:
    then remove the back panel…..
    if u have any doubts get professional help from repairs@
    a 90′ maintenence wash once a month will stop the pressure system getting blocked up in the future.
    Clyde 8)
    #113874
    Many thanks for this 😀
    #113875
    jh21
    Penguin45 – many thanks for this fix. It seems to have cured the ‘no spin’ problem on my Blomberg 1501.
    Cheers !
    #113876
    busby
    Help!! 🙁 My machine is not spinning when loaded it goes into the spining cycles on empty i have done all the cleaning relating to the presure switch at rear of drum every thing works fine when empty, can any one help please
    Best Begards
    Busby
    #113877
    Motor brushes probably worn. You may need these:
    http://shop.ukwhitegoods.co.uk/product_ … cts_id=326
