Blomberg 1501AAA Pump making a noise
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Blomberg 1501AAA Pump making a noise
  • #33698
    Shyde15
    Pump making a noise and the spin cycle not working?
    Any ideas out there?
    Shyde15
    #239701
    RocketMan
    Re: Blomberg 1501AAA Pump making a noise
    Shyde15
    Use the search facility and search for blomberg……
    You should try cleaning pressure bottle first.
    this is one of many threads…..
    http://www.ukwhitegoods.co.uk/modules.p … t=blomberg
    power off and unpluged BEFORE you go near it
    If your not to sure you could try repairs@
    Steve
    #239702
    Shyde15
    The pump is making rattling noise not a chugging noise, I have had the problem before with the pressure bell” becoming choked and cleaned it out which worked fine afterwards
    Any ideas?
    #239703
    Have you actually pulled the filter and had a look for foreign objects? Is the machine draining the water away?
    Shyde15
    Yes i pulled out the filter and it drained it, about 3/4 of a cup of water came out
    I want to have a look at it when i can in from work tonight so any ideas what I should look for?
