have had machine for five years and it’s pretty good but rinse levels are not adequate for work-wear. Can anyone advise how to adjust the pressure switch to raise the rinse levels a bit?
The pressure switch is factory set ,so do not attempt to play around with it, you will most likely end up with a flood . water level should be OK for rinsing. Unless pressure chamber is partialy blocked stopping machine from taking correct level of water.
