Blomberg 1501AAA worth fixing?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Blomberg 1501AAA worth fixing?
  • #49298
    aqualectric
    Blomberg 1501AAA washer. Serial no:- 043011165.
    Drum spider failure – and I can’t find a spider listed for it. The rest of the machine is in excellent condition.
    Anyone know the part number for the drum spider and bearing kit?
    Steve.
    #299465
    robbra
    Re: Blomberg 1501AAA worth fixing?
    Hi Steve,
    I’ve had a post in spares forum for a Blomberg bearing kit and no replies in a fortnight so have told customer BER. Tried Connect parts enquiries but no luck anywhere.
    Rob
    #299466
    Bearings are listed on Connect when you tap in 1501AAA but they’re not cheap. They give the seal dimensions under the picture and you can read 6305(?) just about on one of the bearings when enlarged.
    Spider is obviously going to be more trouble. However, the bearings that come up are listed as WMP1500B (also fit your model). Now when you tap in WMP1500B you get 195 parts available including a spider(descibed as “bearing”). Good pictures; if you got the old one out you could probably say yea or nae.
    Mike.
    #299467
    machine was imported by comet most spares come through them but they are not cheap
