Blomberg 1503 fill level regulation?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Blomberg 1503 fill level regulation?
  • #26946
    Tikkabilla
    Can anyone please tell me how a Blomberg 1503 regulates it’s fill level? Ours is not filling full enough. Is there a sensor or is it based on a timer?
    Regards
    #211989
    Trilobite
    Re: Blomberg 1503 fill level regulation?
    Why do you wish to know?
    Modern washing machines are set to use sufficient water, based upon the absorbency of the load: cotton towels will demand more water than polyester-cotton items. Machines no longer fill right up the door.
    It is not a good idea to fiddle with the hydraulic system as problems can result.
    If you are getting too much detergent residue/soap suds, try reducing the amount of detergent used.; and / or activate any higher water level rinse switch.
    The cotton cycles usually have a more efficient rinse and spin profile, whereas the delicate cycles omit the intermediate spins, but have higher water levels.
    #211990
    Basic water level control is by displacement of air from a collection chamber, up a skinny tube to a diaphragm switch. Modern machines with digital control may use the length of time to reach this level as a marker for timed fill – wool programmes are usually much deeper, for instance. Simpler systems use a multi-level switch.
    The Blombergs have a known issue with the collecting bell on the back of the drum, it becomes choked and causes false levels.
    Power off if you need to inspect it.
    Tikkabilla
    Don’t I just know it 😉 I have to clear it every 6 months or so because spin becomes unreliable.
    The machine fills enough to wash but not if it’s a large load – a bed spread for example. It used to be fine and suspect it is now a problem is because the *insert expletive* plumber put the WM feed in the new bathroom on the gravity supply even though I asked him to put it on the mains. As we have a bungalow the pressure is only about 0.5 Bar and I noticed yesterday the WM instructions state that the pressure should be between 1 and 10 bar. Hence why I am asking if anyone knew the method used to determine fill level. With the 1000 different essential DIY jobs I have lined up I don’t want to have to run a new feed if it won’t make any difference or if the problem is something else.
    I note the pressure switch appears to have a three position sensor, well it clicks three times if you blow in it.
    Regards
    #211992
    Trilobite
    Washing machine fill valves have a ‘pressure reducing washer’ built into the valve, behind the plastic filter.
    On Ye Olde Hoover machines, this was removable, to allow for installations where gravity-feed cold water was used. (The hot water valves on the old Hoovers had no such washer, as they were expected to be fed by gravity; however, should that valve be connected to the cold mains, a washer was available from Hoover).
