Have a BLomberg 1515AAA.
On the Wash cycle – fills with water drum turns about 5 times then stops flashing 1500+600+main wash leds and bleeps
On spin/drain cycle – pumps out water turns drum about 5-10 times and stops flashing 1500+6000+spin led’s
Does some one know what these codes are ? and what wrong with it ?
Have checked water inlets are free / filter is free / outlet is free
drum turns freely – could it be the motor brushes and if so how do I tell ?
Re: Blomberg 1515AAA Can’t fix if I don’t know whats broke
if it is the brushes they will be sparking when the macine is in use but a good check is either to remove them and look at them or give them a firm knock with the handle of a screwdriver will normally give you normal use for long enough to determinr if these were the fault
