Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Blomberg BEO9414X Oven fan motor
- This topic has 7 replies, 3 voices, and was last updated 9 years, 5 months ago by
Twoten.
October 18, 2016 at 9:18 am #89622
Twoten
ParticipantI am trying to identify a fan oven motor for the above single oven.
Model: BEO9414X S.No: 1210107112.
After checking with connections I ordered a 264440102 motor. This motor wouldn’t fit because the fixing holes are threaded so the screws come through from the back of the oven into the motor. The motor that’s fitted is held in place by 3 self tapping screws that are fitted from behind the oven. The holes are not large enough for the self tapping screws.
Also the original motor that is fitted has a cowl round the cooling fan part number STV082639711 but when ordered it was identical to the 264440102, in fact it had this part number on a hidden Beko label.
I had this checked with Connect and it turns out the bin had 2 types in but the other type was BEK264100010 so still doesn’t have a cowl.Can anyone confirm if the appearance of this fan motor has been modified and what the fixing should look like now?
October 18, 2016 at 2:29 pm #441896kaibart
ModeratorRe: Blomberg BEO9414X Oven fan motor
Try this part number see if it’s the fan motor you want most common ones used on beko ovens BEKBE264440102 qualtex do pattern 1 to mtr308
October 18, 2016 at 2:52 pm #441897don
According to Manu Soft it’s the attached motor which is part number 264440128.
Hope Connect don’t mind me lifting the picture.
DonOctober 18, 2016 at 6:51 pm #441898Twoten
ParticipantRe: Blomberg BEO9414X Oven fan motor
Thanks for the help.
This is the motor that was fitted as original.The cowl is riveted and the fan pressed on to the shaft so I don’t think 264440128 will work don.
I was tempted to go for the MTR308, I looks like it will fit but I wasn’t sure if the cowl did anything for the airflow or it is just for mounting.
The BEKBE264440102 looks like it might be another alternative. but was hoping that someone would know which the replacement for the in the image.
has anyone used the MTR308 and know the reliability?October 18, 2016 at 7:43 pm #441899don
I have found the service document as attached for this oven and the change of fan motor. This is from Arcelik themselves.
DonOctober 18, 2016 at 9:08 pm #441900Twoten
Thanks for the tech info don.
Looking at the picture the motor has to be attached to an ‘oven cooling fan mounting sheet’, I think I have found this at connect 5045178534693
According to the tech info when fitting to the oven it should push and lock but I’m sure the back of the oven wasn’t cut to take the bayonet tabs/fitting. Also this is not listed as a part required in the conversion.
The picture of the old motor 264440104 in the tech sheet doesn’t match the one that was fitted so not sure if this applies to the above appliance?October 19, 2016 at 7:34 am #441901don
Twoten wrote:so not sure if this applies to the above appliance?
Beko made oven the info was taken directly off the Beko service site .Sadly I cannot get any higher 😉
DonOctober 19, 2016 at 8:46 am #441902Twoten
Thanks don, the help is appreciated.
