Re: blomberg CFF311 fridge freezer temp
cant see a lot of info on this one
first you may have model wrong I can see CFFN311
if so your unit is a non frost free and I think the stat in the fridge controls everything ( others members may have more knowledge)
does the motor seem to be running all the time ?
if yes then you have a compressor or gas problem. either way its a professional only repair and may not be worth it if the compressor has failed
