Blomberg door hinges rusted through
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Blomberg door hinges rusted through
  • #10295
    I have a fairly old Blomberg oven (model 1750 LX-KM-W). The door has come off as the hinges on both sides having more or less disintegrated. The housing/slots which hold the hinges on the oven itself are shot too. although the door itself is fine.
    Do you think the hinges can be replaced (if they still make them for this model) and is it a DIY job?
    Thanks for your help
    JR
    PS The plate with the model no. etc is fairly worn. It also says what looks like: Acl 108294 or it could be Acl 106294and gives the grill spec as 2500 W.
    #139411
    daza
    Re: Blomberg door hinges rusted through
    hi best option you have is to phone comet cust care,as they will be able to help as comet do all warenty work for blomberg, although you will need coorect model no
    #139412
    You can also try http://www.cometspares.co.uk
