I have the above fridge freezer, its over 10yrs old. It was recently moved to lay a floor, it remained upright. Following this my cleaners cleaned the inside.
The center compartment can either be a fridge or a freezer. We have always left it as a freezer.
4 days ago the center variable compartment defrosted. I am unable to make it freeze again. The top fridge works and the lower freezer is frozen.
When the center compartment is set to freezer the green indicator flashes indicating a fault, and sometimes the red freezer warning light is on. I have tried altering the temperature controle nob for the center compartment both colder and warmer (each time leaving it for a few hrs) with no effect.
I have moved the multi function compartment switch to 0’c and moved the adjustable temperature selector at the back of the center compartment to +3/0 setting and the 0’c+3 light lights appropriately.
When all controles are moved back to the freezer settings againe then the lights flash.
Has anyone any ideas on how to fix it?
Look forward to hearing from you
John
