Blomberg GVN 9483E
  • #96458
    andyjawa
    Hi. This is a built-in Blomberg but I think it is a rebagded Beko. Comes up with fault code 5 and 9 apparently because I myself have never seen the fault codes. I can tell you the the machine went from start to finish on the quick wash just fine. I can also tell you that the bottom wash blade is worn and so jams against the top of the salt cap, perhaps that accounts for f/code 5 ref Beko f/codes as something to do with turbidity? As for 9 no idea, anyone please?
    #463446
    Moved to correct forum. 😉
    #463447
    fault codes
    if you more info let me know
