Blomberg GVN 9483E fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Blomberg GVN 9483E fault
  • #99130
    Sandydog
    Hello
    Can anyone help with an error code on my Blomberg dishwasher model number GVN 9483E?
    I have run the self test and it is showing Er5.
    The reason for running the test is that the lower arm is not spinning. I’ve checked it for blockages and there are none. Water is coming out of the arm.
    Thanks!
    #475136
    Er5 is a diverter valve fault
    fault reads “3W Valve Position Error”
    https://shop.ukwhitegoods.co.uk/1760400100-dishwasher-diverter-valve
    valve may be faulty, bad connections or main board fault
    Sandydog
    Thanks Dave, much appreciated.
    #475138
    Sandydog
    Hi again
    It seems like the connectors are burnt out. Is repair an option with a new valve or is the wire connector either not fit to use or not replaceable?
    Is there an option just not to connect it back at all and use the dishwasher without those burnt wires connected? Sorry if it’s a stupid question, I’ve no idea what the red/purple wires are responsible for!
    [IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”height”:”800″,”width”:”600″,”src”:”https://i.postimg.cc/DfdKw4mw/9-B3-D6-AD1-3-E61-40-E8-91-B3-D419-EF218-D30.jpg”}[/IMG2]
    [IMG2=JSON]{“data-align”:”none”,”data-linktype”:”1″,”data-size”:”full”,”height”:”800″,”width”:”505″,”src”:”https://i.postimg.cc/4NfR74hb/8-E1-EF625-A4-FE-4054-B713-6-A2-FFCF7-AC81.jpg”}[/IMG2]
    [IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”height”:”800″,”width”:”600″,”src”:”https://i.postimg.cc/7YK8gv3v/A9-B5-BA60-C092-47-A5-8787-187783-F5-D73-D.jpg”}[/IMG2]
    #475139
    for that to happen it must have got wet
    Sandydog
    I can’t recall any problems with water going where it shouldn’t. But if there’s a leak somewhere maybe it’s time to bin the dishwasher anyway.
    Is that what you’re saying?
    Christine
    #475141
    as you say it cant be much but its likley that whole unit has been leaking
    all depends if you want to take a £25 chance on a fix
    you could remove the unit and look to see if its been leaking
