Blomberg GVN9483E DW – no heat – heater etc good
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Blomberg GVN9483E DW – no heat – heater etc good
  • #90698
    RocketMan
    Lost the will to live with this one and it’s only Monday! A chuffing nightmare to get out!!
    Basically a posh Beko in a dress.
    Heater, good, pcb looks good no burns or dry joints, no apparent cable breaks at the bottom of the door etc.
    Got to go back to this tomorrow when I’ve got more time. No apparent fault code.
    I didn’t check the ntc- I seriously cannot remember the last time I replaced one that was genuinely faulty. I will check it.
    Are there any other little anomalies to check on Beko DWs that cause no heat? Everything else seems to be ok. Thermal cut out??
    Help or advise welcome along with a either a skip for it or a few beer for me to keep my sanity.
    #445673
    Re: Blomberg GVN9483E DW – no heat – heater etc good
    yes its a Beko
    if you want tech info let me know
    RocketMan
    It took ages but I did sort this one. I eventually got it to work for a few minutes so it pointed me in the right direction.
    The fault was a break in one off the ntc wires. It looked ok, the plastic insulator was all ok but it was broken inside. Which probably explains why continuity on the wire was ok when I tested it. Thanks Dave for the help
    #445675
    well done for finding that
    nice feeling when you crack a hard one
