Blomberg int 45 dishwasher leaks
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Blomberg int 45 dishwasher leaks
  • #99138
    Kentish
    So I’m feeling rather stupid, as I have a LDVS2284 Blomberg integrated 45 dishwasher that spits in the bottom right corner of the door.
    There is no visible door or hinge deformation and the door seals are new, but still every now and then when the spray arms are mainly at the bottom one it spits and splashes up and out down the hinge metal or over the cabinet lip.
    Has anyone had this or is there a mod for it, as all I can see is some sort of splash plate “mod” to direct the splashes back into the machine.
    Cheers
    Kentish
    #475161
    clockworkone
    I had a Beko cousin doing what seems to be the same. Water was landing on top of rh hinge and splashing. Very hard to see. I filed the top of hinge inwards so rather than landing and splashing the top was sloped and encouraged water to go back into cabinet. Also made sure Dw was leaning slightly towards the back.
    #475162
    Hollytree_Technical
    Have you checked that the spray arms are not split down the seam?
    Jem
    #475163
    Kentish
    Hollytree_Technical wrote:Have you checked that the spray arms are not split down the seam?
    Jem
    There was nothing obvious when I looked at them, but it may be prudent to at least have one with me if it comes back.
