Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Blomberg knm4551i fridge freezer problem
- This topic has 9 replies, 2 voices, and was last updated 2 years, 9 months ago by
shillo.
June 23, 2023 at 7:15 am #102041
shillo
ParticipantBasically the fridge is not cold enough but the freezer is. I have rather randomly replaced the thermistor and thermostat I think. both easily to replace and sounded like the most likely culprits. The defrost element seams fine, the coils were iced up but after defrosting it has not iced up again. Any ideas what to do next. My wife just want to replace it but I’m stubborn/stupid!
June 23, 2023 at 7:56 am #487329electrofix
Moderatorok the freezer maybe ok temp but have you measured it ?
does the compressor switch off or iis it running all the time ?
these systems cool the freezer first and only when that gets down to temp is there enough gas left over to cool the fridge. if the freezer is not cold enough the fridge will never cool. if the compressor never stops apart from the energy cost it will mean a tired compressor or low gas levels
June 23, 2023 at 10:48 am #487330shillo
Participanthi
the compressor seams to be running all the time.
fridge is at 1 degree and set to max on the thermostat
freezer is at -3 degrees but that was as low as my thermometer went.
Plastic panel between fridge and freezer is warm to the touchJune 23, 2023 at 1:47 pm #487331electrofix
Moderatorsound like your wife is right
you need to get a better thermometer. if food is not kept at -18 or below it wont keep as long. it could be -5 which would be dangerous for long term storage
How Long Does Food Last In The Freezer? A Food Safety Guide (highspeedtraining.co.uk)
June 23, 2023 at 5:24 pm #487332shillo
ParticipantThe stuff thats in there seams to be well frozen
June 23, 2023 at 10:07 pm #487333electrofix
Moderatorshillo wrote:The stuff thats in there seams to be well frozen
it can be well frozen at -10 but its not safe
June 29, 2023 at 5:55 pm #487334shillo
Participantok my fridge thermometer arrived.
its -21 in the freezer and +9 in the fridge
June 29, 2023 at 6:21 pm #487335electrofix
Moderatorwell that sort of makes no sense now
have you got ice forming on the back wall ?
June 29, 2023 at 8:05 pm #487336shillo
Participantthere was before I defrosted it but no more has reformed at all, I haven’t put the back cover back on so everything is exposed still and its been running for a week now.
June 30, 2023 at 5:42 pm #487337shillo
Participantany ideas anybody?
