Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Blomberg oven not heating up
- This topic has 11 replies, 3 voices, and was last updated 21 years ago by
hlmsdog.
March 27, 2005 at 12:21 pm #8707
hlmsdog
ParticipantI have a Blomberg oven type B15E Model no. EOD609SS/1 Serial no. O846BM121. The bottom door fell of the other day. I have managed to put it back on, but ever since the bottom oven does not warm up. The door seal is fine, but the oven just isn’t getting warm. The top oven and grill works fine. Any ideas please people. If it’s something like a thermostat that needs repairing or replacing, where or who can I call out to sort it?
March 27, 2005 at 1:37 pm #130100Dave_Conway
ParticipantRe: Blomberg oven not heating up
Does the oven appear to be working (Lights on, fan running) etc but just no heat ?
March 28, 2005 at 1:09 am #130101hlmsdog
Yes. Fan and light ok. Just limited heat yesterday. Absolutely no heat today. Help!!
March 28, 2005 at 5:16 am #130102kwatt
KeymasterJust the fan element away then, almost for sure. Dave should be able to get one but I dunno if he’ll be ableto price it till Tuesday due to today being a public holiday.
March 28, 2005 at 7:00 pm #130103Dave_Conway
This one in the shop will be the one you need:
March 28, 2005 at 8:49 pm #130104hlmsdog
Thanks. Is this something that I can fit myself, and how?
March 28, 2005 at 9:43 pm #130105Dave_Conway
All I can tell you is that the element is behind the rear panel in the oven, any more than that I will be crossing legal boundries by giving technical information.
If you’re unsure, please check repairs@ and the directories for an engineer, if you decide on having a go, make sure it’s disconnected from the supply 1st :zap:
March 29, 2005 at 9:24 am #130106hlmsdog
Whilst sitting on the legal fence, can you tell me if it something fitted through the inside of the oven, or by pulling it out of the kitchen units to get access to the rear?
March 29, 2005 at 9:54 am #130107Dave_Conway
It will come out through the oven but you may have to remove the oven from the housing to access the fixing screws for the element.
April 10, 2005 at 4:49 pm #130108hlmsdog
The link you gave me above lead me to an element item no. ELE4503. I ordered it and received an invoice for it and then received your delivery. The item I have received is ELE2051.
I fit it, and it works fine, but it is ever so slightly smaller in circumference than the one I took off, and will not allow the fan to spin inside it.
Is this because it is the wrong item? and how quickly can you send me the correct item?
April 10, 2005 at 5:00 pm #130109Dave_Conway
ELE4503 and ELE2051 are actually the same part just from two different suppliers.
It sounds like it’s poorly manufactured to me 🙁
I’ll get another one out to you tommorow, sorry about that.
April 10, 2005 at 5:03 pm #130110Dave_Conway
PS, I removed your phone numbers from the post, this is a public forum 😉
