Blomberg WA1300 – Won’t flush powder or start rinse cycles
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Blomberg WA1300 – Won’t flush powder or start rinse cycles
  • #14660
    Dickie
    I’m no expert but it sounds like the cold water may not be getting through?
    If I manually flush the powder it continues (with water from the hot feed I presume) until it gets to a rinse cycle and then it stops. Perhaps a cold inlet valve or some sort of solenoid not working?
    This is an old machine and we’ve had excellent service from it, however, I don’t want to bin it if it’s a ‘simple’ replacement part of some sort.
    Anyone got any ideas?
    Also, if anyone knows part numbers and where to get the part(s) this would be really helpful.
    Cheers,
    Richard.
    #160361
    Re: Blomberg WA1300 – Won’t flush powder or start rinse cycl
    That’s the old Ocean-built Blomberg, IIRC. One of these:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=415
    should do the trick.
    Always assuming that the cold supply is on…….. Those little blue tags wear and don’t always turn the water on. 😀
    Power off if doing this yourself.
