Blomberg type:WA9001314 Ident.nr.0020607300-142111999 after repairing the faulty module (some transistors who comands the relays) is showing now some smile to me ” the LEDs from 900 +400+End are flashing”.
Do any know the error codes from blomberg???( electronic IVENSIS like in whirlpool).
baron
Don’t think we’ve seen the fully digital Blombergs over here yet, Baron. Does it do anything at all? Is it the usual Brandt production? Do you know what the failed components controlled? If the heater components failed, I’d be looking at the heater itself for earth problems….
Yes Cris. The first transistor which I changed it was from heater relay but was from motor relays also one.
The simptom was: even not powered on(just pluged) those relays were activated. After that I’ve had to change also the transistor which comands motor triac. The washer it goes fine to times and gives that error now.
I have checked the heater to ground but nothing (15MOhm).
