Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › BLOMBERG WA295 1503AS WONT SPIN
- This topic has 6 replies, 3 voices, and was last updated 20 years ago by
01milky.
March 28, 2006 at 9:03 pm #16745
01milky
ParticipantHI
CAN ANY KIND PERSON OUT THERE PLEASE HELP
I HAVE A BLOMBERG WA295 1503AS WASHING MACHINE WHICH WILL NOT SPIN. THE PUMP RUNS AND EMPTIES MACHINE WHEN DIAL INDICATOR GETS TO SPIN PART SOUNDS AS IF PUMP IS STILL RUNNING DRUM TURNS FORWARDS AND BACKWARDS SLOWLY THEN IT SOUNDS AS IF IT WANTS TO WIND UP TO FULL SPEED(AS THE TONE OF THE MOTOR CHANGES) BUT NOTHING JUST GOES BACK TO SLOW.
I HAVE SWAPPED THE MOTOR WITH A SPARE I HAD ALSO TRIED CLEANING THAT PRESSURE BELL BUT STILL THE SAME.
HELP I HAVE 4 YOUNG KIDS AND THE WASHING IS BUILDING UP
01MILKYMarch 28, 2006 at 9:11 pm #171367Penguin45
ParticipantRe: BLOMBERG WA295 1503AS WONT SPIN
Check this as a starting point:
http://www.ukwhitegoods.co.uk/modules.p … lomberg+13
Power off if investigating.
Penguin45.March 28, 2006 at 9:36 pm #17136801milky
THANKS PENGUIN 45 FOR THE QUICK REPLY
AS THIS PRESSURE BELL KEEPS POPPING UP IN THE REMEDIES HAD IT OF AGAIN AND IT LOOKS CLEAN ALSO GROMMIT IS CLEAN.
BUT WHAT I HAVE DONE IS PUT IT ALL BACK TOGETHER BUT TAKEN THE RUBBER PIPE WHICH COMES OF THE BELL OF WHAT I PRESSUME MUST BE A PRESSURE SWITCH AND THE MACHINE SEEMS TO SPIN FINE NOW.
SO I SUPPOSE SOMETHING MUST BE BLOCKED SOMEWHERE.
CHEERS
01MILKYMarch 28, 2006 at 9:52 pm #17136901milky
HI ONLY ME AGAIN
FALSE HOPE PUT A LOAD OF WET WASHING IN TO DRY AND NOTHING BUT SLOW TURNING AGAIN.
01MILKYMarch 28, 2006 at 10:10 pm #17137001milky
HI IVE EMPTIED THE MACHINE AND SPINS AWAY AT 1500RMP NO BOTHER.
HELP
01MILKYMarch 28, 2006 at 10:34 pm #171371Dave_Conway
It’s either detecting an “out of balance load” then or either the brushes may be worn or it’s not emtying fast enough.
Have you checked the filter ?
PS, turn the CAPS LOCK off eh 😉
March 29, 2006 at 9:28 am #17137201milky
thanks for all your help
the filter and the brushes are fine. got the machine to start working @ 1.30 last night dont really know what was causing problem but suspect it was a balance thing.any how thanks for your help everyone. this is a really good site with lots of quick good advice.
01milkyps sorry for the caps
