Blomberg washer.
  • #94548
    clockworkone
    Blomberg wnf8447a40(7174182800) This machine will only perform what seems to be an anti flood action ie it will just keep turning on and off drain pump.It sticks at 59 min. Reset will not operate. Could this be just a digital pr sw failure.Paul.
    #457644
    Seamy
    Re: Blomberg washer.
    Morning Paul,
    Make sure machine is not connected to hot water supply instead of cold.
    Saw this when appliance was on wrong supply, the N.T.C, senses the temp’ & will bring in cold water to cool down, run pump, bring in more water, run pump etc.
    It will do similar if it notices excess foam during the rinse cycle, the pressure goes up after short distribute, so it stops, brings in water & does pump out to try to clear.
    Try blowing down pressure hose from p’switch, obviously don’t blow into p’switch.
    N.T.C or heater may be faulty either, they cause lots of strange issues with electronics on these Beko’s.
    Check drain hose isn’t down too far down standipe, (syphoning), it can cause pressure sw’ to get strange readings also.
    #457645
    clockworkone
    Thank you Seamy. This one has me stumped. Tested heater,ntc,water connection,pressure tubes.Replaced dig pr sw as cost was low.No joy.Having thought I had all ancillaries covered i went for new board and guess what,fault still there.Dont want to give up but running out of ideas.
    p.s New board came in a box that i suspect had been opened previously.No bubble wrap or protection inside box. Could I be that unlucky.
    #457646
    did the board come from connect as I have had them do that to me and send me faulty stuff as other engineers had blown them up
    see if this helps
    clockworkone
    Thank you Dave for reply and error codes.Module came from Irish supplier. I have asked in the past for them not to send me previously opened modules. This machine is a bit of a head wrecker.Thanks again.
