Blomberg washer 1500AW main circuit board
Home Forums Public Support Forums Spare Parts Help Blomberg washer 1500AW main circuit board
  • #9359
    pilott
    Hi ,
    Am looking for the main circuit board/ timer control for a blomberg 1500AW washing machine. The numbers on the label are as follows:
    “TYP
    513 501
    BLOMBERG- 12 113 10
    258″
    #133701
    Re: Blomberg washer 1500AW main circuit board
    You absolutely sure about this? The machine is a Comet exclusive, part number is 55×6544, £153.78 plus VAT and P+P. 😯 Before spending your dosh, might be an idea to explain your problem.
    pilott
    Penguin45 wrote:You absolutely sure about this? The machine is a Comet exclusive, part number is 55×6544, £153.78 plus VAT and P+P. 😯 Before spending your dosh, might be an idea to explain your problem.
    Yes you are correct, it was Purchases from Comet.
    Re the fault. The water keeps filling the drum and eventuallyrises to a level where it breaks the door seal and leaks. The circuit board has many black, sooty tracks across it. ❓
    Sounds terminal at almost £200
    #133703
    Check this first………
    http://www.ukwhitegoods.co.uk/modules.p … t=blomberg
    The black marks may just be dusty deposits – pull the plug before investigating.
    pilott
    penguin45
    You are an ABSOLUTE STAR!!! What can I say…………
    The other thread proved most useful, and in unclogging the “bell chamber” I found that the hose leading from it had worn away aginst the back of the drum allowing air to enter. Hose replaced for 25p and all now seems well…fingers crossed.
    Once again, thank you very, very much. 😀 😀
