Blomberg WNF 8427 Error Code F05
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Blomberg WNF 8427 Error Code F05
  • #96576
    Mister Kew
    Hello
    My Blomberg WNF 8427 has stopped mid cycle, showing the spin icon and 20.00 left to run. I have accessed the error codes and its giving a F05 error code.
    Can anyone please confirm what the error refers to..and also is there a way to reset the error log ..ie a machine full reset ?
    Thanks in advance
    #463967
    you seem to be in Greece by your ip address
    cant find you model because we are in the uk but looking at a similar model it might be a pump out problem so check filter and discharge hoses
    Mister Kew
    Hi, Thanks for your reply..The pump after removing the impeller cover will spin by hand ,,, the filter is clear..indeed out of the machine.. Its really difficult to get the the black rubber outlet from the drum..( it looks like its only accessible from the front?? But on squeezing it, there appears to be a ball shaped object inside..I presumed this was some sort of floater device to stop the water just running away?? and that it was normal for it to be in there.. any other offers ??
    #463969
    that’s an eco ball it stops the detergent from ending up in the lower hose, where it would be no where near the washing Dave
