Blown timer neff s4456n
  • #27083
    streetlighter
    Hi all
    Just been to a neff dishwasher which wont program or start.
    The timer has blown conponents on the module. (2 tranys and the track)
    neff 483261 which is £90. Tested motor and part of the heater ( couldn’t get the integral d/w out ) also the dispensor. All seem fine.
    Is there a comon fault on these or could it just be the old dispensor problem ( which I have never seen before ) but it did test ok 1.2kohm ❓
    this is not the normal boshe module but a slightly smaller version.
    Ta for any help replacement integral d/w is dear so cons is prepared to pay a bit, but I can’t afford to destroy a £90 module.
    Paul
    #212526
    Re: Blown timer neff s4456n
    That’s a tough one Paul to be honest. The dispenser solenoid is a known cause of modules blowing but by the same token the heater and its water point device can be suspect? Tracing the area of the blown components down through the wiring harness may point to the troublesome device? That’s not so easy but is your best hope. 😉
    #212527
    streetlighter
    Thanks martin
    I think it was the track to the dispensor and the aparently the dispensor has not worked for a while 😕
    Thanks again
    Paul
