Boch WAT 28660GB/01 severe vibration ob fast spin cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Boch WAT 28660GB/01 severe vibration ob fast spin cycle
  • #97728
    stella.a
    I’ve have the above machine. Yesterday whilst on a fast spin cycle there was a loud bang and then it walked across the floor. I just assumed it was badly loaded so put it back, made sure it was level etc and tried again.On wash cycles it’s fine, but when it fast spins it bangs as it runs up then bangs intermittently whilst spinning. Any ideas what may be the cause please. We’ve had it since new and up til this its been fine…..Thanks
    #469219
    has it been making any noises of late other than whats happened ?
    does the drum look like its in line when you look in the door ?
    stella.a
    Drum is in line with the door. Nope, no other noises only when it ramps up to spin. The drum, when turned by hand, turns nice and smoothly too, no grinding or crunching
    #469221
    what i am after is the inner drum. i realised the drum would be inline with the door but what your describing sounds like the inner drum spider has failed. the spider has 3 legs and when one snaps the drum moves when on spin and contacts the outer tub. the only clue is some runout of the inner drum when its truned. what your looking for is a change in the gap as its rotated between the 2 drums. a small amount is ok but if it get beyond 5 mm its getting too big
    stella.a
    electrofix wrote:what i am after is the inner drum. i realised the drum would be inline with the door but what your describing sounds like the inner drum spider has failed. the spider has 3 legs and when one snaps the drum moves when on spin and contacts the outer tub. the only clue is some runout of the inner drum when its truned. what your looking for is a change in the gap as its rotated between the 2 drums. a small amount is ok but if it get beyond 5 mm its getting too big
    Thanks Dave
    Nope it doesn’t seem to be moving…..it runs true…….
    #469223
    check all the concrete weight are secured and not damaged
    also check the motor is secure and none of the mountings have got damaged
    if they are ok it can only be 2 things
    either the whole drum assembly is hitting the outer case or the inner drum is moving and hitting the outer one
    the only long shot is if the heater has come loose and hitting the inner drum when trying to spin
    How loud is thsi bang could it be coins stuck between the drums which tend to move when the machine spins
    does it make any noises with no washing in ?
