Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bocsh SHV43A03GB/42 No response from rest
- This topic has 7 replies, 3 voices, and was last updated 8 years, 4 months ago by
asp11.
November 28, 2017 at 8:38 pm #92730
asp11
ParticipantFills up then pumps a bit and contiues doing this with door open or closed…… Problem is all the lights are on every button and the reset isn’t working so it cant be cancelled and restarted again.
Don’t want to change pcb as its expensive but it must be the fault – or is it?
CX has kept up Calgon treatment so the air break will be good, so I’m guessing the pcb is the problem.any ideas please?
November 29, 2017 at 5:12 pm #452007asp11
ParticipantRe: Bocsh SHV43A03GB/42 No response from reset
asp11 wrote:Fills up then pumps a bit and contiues doing this with door open or closed…… Problem is all the lights are on every button and the reset isn’t working so it cant be cancelled and restarted again.
November 29, 2017 at 7:01 pm #452008eastlmark
ModeratorRe: Bocsh SHV43A03GB/42 No response from rest
sounds like pcb, any water in base though? Nothing earthed? Would give the pcb a good inspection though, look for blown out components otherwise a new one might blow on fitting.
November 29, 2017 at 7:57 pm #452009Martin
ParticipantRe: Bocsh SHV43A03GB/42 No response from rest
I’m curious to know what “the calgon treatment” is ❓
November 30, 2017 at 1:07 pm #452010asp11
Unlike most customers, this one uses calgon every month which I said was fantastic
November 30, 2017 at 4:00 pm #452011Martin
asp11 wrote:Unlike most customers, this one uses calgon every month which I said was fantastic
But please explain what calgon product is this person using every month?
December 5, 2017 at 12:36 pm #452012asp11
Just the normal descaling tablet as far as I know, why is that too regular?
December 5, 2017 at 2:10 pm #452013Martin
asp11 wrote:Just the normal descaling tablet as far as I know, why is that too regular?
It’s just that Calgon don’t make such a product for dishwashers and I was assuming your customer was therefore using the same stuff as Calgon make for washing machines, maybe?
